towpainter3
New Member
ok gonna start off by sayin hello! Brad here on this end.
I need some help with a 727 thats doin something weird when it goes in gear.
heres the skinny, 79 727, installed the basic transgo shift kit in the valve body, did a few vent mods to help it stay water tight under 4 wheelin conditions, and cleaned her out good then resealed it.
this thing double hits when you put it in the forward gears, you can feel it take the gear then it bumps again.
hot or cold doesnt matter, it shifts like a champ , clean crisp bumps through all three gears with no slipping or weird noises.
i have double checked the kickdown and shifter , they are correct.
i guess i left out the fact it was good before i did all this cant recall it ever doing this. any advice or help on this would be greatly appreciated.
thanks Brad
thanks Brad
