360moparjunkie
I have a fresh 727/360/4k stall installed in the 73 dart/scamp.
Trans has reverse manual valve body. I have no prev experience with these.
1. Do I need to hook up the kick down lever on the side of transmission? All this hardware is missing from prev owner.
2. Will the transmission shift on its own 1-3 in drive or will I have to manually shift 1st-3rd each time I drive.
3. Will leaving the kick down lever unhooked cause shifts to always be soft even at full throttle shifts?
Thank you.
Thank you.
