Yeah I agree it sounds too loose. The adjustment is very critical and if you run it out of adjustment your asking for trouble. As in a roached trans. Get it fixed before you drive it or you'll be sorry. To adjust it properly torque it down to 72 inch lbs. then back it off 2-1/4 turns. Like Mike said make sure when you tighten the locknut your not turning the adjustment also.
