Can you put a steering column from say a 74 duster to a 65 valiant with a push button . I know you need linkage and all but will steering column and push button trnny work together
I bet you don't EAt SLeeP and **** all MOPARs. Why would you want to change a push button to a column shifter, Done right, the look of the push button blows people away and is simple to use...
1965? where does his shift now? some of those 1965 cars have a cable inside the column. also the the newer column might have a larger shaft connector. Lawrence
The later model column will not work with the cable shifted transmission. You will have to find an early A cable style steering column with the shifter on the column.
