Hyperballsmcgee
from the researching I've done so far this has happened to alot of people. I was a ford guy who made the wise decision to switch to the mopar side of things, and I'm absolutely loving it, except I can't figure out this tranny for the life of me. on my 74 maverick the c4 tranny was eating up fluid an not shifting right, replaced the vacuum mod and all was good, but the tf727 on my 74 scamp also appears to be sucking fluid down like gas, but there's no smoke out the exhaust, and from what I can see and read there's no vacuum mod. I'm not too savvy in the Trans department, so any help at all is appreciated!
I suppose y'all need the symptoms. besides going through fluid, the shift points(with fluid in it) are: 1st to 2nd: 25 mph, 2nd to 3rd: 55 mph. when it gets down to 40 mph it slams back down into second. sometimes at a red light it doesn't go back to 1st. it also absolutely will not shift manually (1-2, 2-D). I'm used to the c4 tranny shifting EXACTLY when I told it too, as well as (when it was in drive) going into 3rd gear when it was coasting.
thanks for reading and thanks in advance for any and all help!
