stealthcorrado
Member
Hi, I just installed the lowkar kick down cable and thought I adjusted the cable correct, it will shift good from 1-2nd and then it will shift into 3rd at a high rpm (around 3,000-3200). I'm gonna try some more adjustments tonight after work, so I figured while I'm working to post and see if anyone has had a similar issue to what I'm having and to maybe try when I get home. Thank you
