69signetv8
Would like a few conformations from you guys that have installed the Transgo TF-2. Just to let ya know, I have read all the past threads and the installation guide abut 4 times "slow time". It seems pretty straight forward overall.
Now without my trans apart at this time "I" believe it's a 72...until I take the valve body off to really know for sure! . If so, it would have a 3-2 part throttle assembly.
#1. I would like to know if I should install the "black spring" that eliminates part throttle 3-2 shifts above 40MPH? (I don't have a clue).
Also, I'm not putting in the SHIFT COMMAND (as I have read about)
#2. If I read correctly, "I" still have to grind down the throttle valve "correct"
If this helps to know, 318 /360 heads, 2500 stall and 3.91 gears. (just fun street stuff) for say. No strip??
Thanks, I hope I won't have anymore questions until it's together ready for setup.
jim
jim
