d55dave
I am working on a friends torqueflite and have a question. What I am starting with is an early 80's non lockup 4X4 727 that has been built into a big block main case (the case is a 70 or 71 vintage). All the internals appear to be early 80's 318 truck parts, nothing special. The transmission was recently rebuilt and working fine, but needs to be converted from the 4X4 configuration to a passenger car long tailshaft slip yoke style for use in a 70 Barracuda.
I understand that the spline design on the front of the output shaft changed in 1976. I have a complete 1968 318 2 wheel drive truck transmission that I would like to use the tail housing and output shaft from. Can I use these in conjunction with the early 80's internals and earlier big block main case? What other parts do I have to swap along with the shaft and tail housing? I suspect at least the rear planetary, anything else?
Thanks for any help.
