You can plug the hole in the pump, preferably by tapping the hole to a pipe thread (eighth inch) You may need to drill it, and installing a plug.
Then drill a hole and tap it in the top of the tailshaft housing about 3.5" from the back of the case and installing a tube loop or an extension hose to where ever you want the vent to be.
