'Cause
need lots of parts
MY ERRROR... IT WOULD NEED TO BE A 1973.
This is an alternative to not being able to find a GOOD complete door.
I will attempt to explain. I would like to get the "inside" part of the passenger side of a door.
The car was a 'Drag Car' all of it's life and as such the Body is excellent,but, the entire inside of the door was cut away, I assume for weight reduction.
As seen in the photo the exterior is near perfect, the entire car is this way. I buffed some of the door forward paint to get a good look at it. I intend to put this together and on the street. (retirement Project)
Now in the second picture you can see what was done to the inside of the door.
There has to be a bad, damaged right door out there some where that the inside half is good and could be cut away and sent to a person in need! Yes I can weld and fix it if I have the inside part of the door. Yes, I am willing to pay for it, not asking for anything free.
If you can help this disabled/retired Vet out it woud be greatly appreciated, So please look around if you have a worthless crunched, even rusty (to a point) door, could you cut out the the part I need.
I appreciate the attention, Thanks
Ken
The exterior of the door, it is just too nice to trash.
The interior of the same door!
(if it could be cut down the sides from the window and across the bottom of a damaged door I can save this thing!)
His New stroker 416 and 727 tranny are built and waiting
Ken
