Time to clean out the garage, everything OBO plus shipping.
I have for sale two sets of strut rods. One from a 73-76 and A body and the other from 64 A body. The are the same except the 73-76 has a pin hole. Each set is $45.
Upper drum control arms from 64 Valiant. Needs new bushings and ball joints. $25 for both
Drum Spindles from 64 Valiant in good shape but dirty, $50 for both
Backing plates and all the hardware I could keep for drum 64 valiant, $25
Two sets of big ball joint 73-76 upper control arms. One set is ready to bolt on but I drilled a hole (see pic) to use a front end limiter. Was on my drag car until I changed suspensions (easily welded up). Standard bushings and good ball joints. $125. Other set has okay offset bushings and ball joints but I would replace them but that me. $100
One set of 73-76 disc spindles in good shape. $100
Two sets of lower control arms. One set is good to go, bushing looks good, with torsion bar adjuster, $75. Other set need rebuilt, $40
One steering link from slant six Valiant, $25
One steering link from 73-76 (needed for disc conversion), $75
Slant 6 170 intake manifold and exhaust manifold. Heat riser is not frozen. $25 each
Slant 6 valve cover and breather, $15
Slant 6 adjustable rockers and shafts, looks okay, $35
I have other parts, I need the garage space. All is OBO plus shipping. Many other engine/tranny parts including push button, etc....just ask.
Thanks Chuck
Thanks Chuck
