abdywgn
dismantler
std. bore 401 block,crank with std. size rod and main bearings,connecting rods and std. size pistons. It appears I am the first to take the short block apart as the bearings have 72 dates and are stamped AM. also 1 pair of heads (291 casting I believe) with screw-in studs, rocker arms and pushrods. There is also a front cover with oil pump and a 3-bolt balancer. Parts are located in Darien IL. $1,320 for the above parts.
