What your going to see in the pictures is a very complete BBP front suspension off a 1973 340 Dart Sport. This sale ad is for the K-Member alone. But as you can see in the pictures it is a complete down to the bolts for everything to install a complete front suspension. This all came off the same car. The car was recently restored or restomod. The components I left on as they are still usable and in good shape. Ball joints,bushings,Calipers,hoses, rebuilt PS box that was bone dry , no leaks.A rebuilt PS pump with all the brackets for a small block, strut rod bushings.
Even the Gas Monroe shocks are still good. Has LCA's with sway bar tabs and the sway bar.
Rather than a bunch of different ads, I figured I would try listing the K-Member as a start and let you add on what you want. If this doesn't work I'll list pieces separately. Literally all you need is bearing grease and brake fluid and you have every think here to add a complete front suspension to your 67 and newer A Body. Kind of like build a Bear! Let me know what all you need and I'll add it to the cost of the K-member. $250.00 Prefer local pick up but I can also palatalize and ship terminal to terminal thru YRC freight.
