None of the pre-73 cars had any reinforcement behind the bumper, they bolted straight to the brackets. Given the size of the later bumpers, even without the reinforcement they're stronger than the earlier bumpers (and heavier).
As far as collision damage goes, those bumpers were reinforced as part of a 5mph impact test mandated by the government. That's where the big rubber guards came from too, and the shock mounts on the '74's. In low speed impacts, they'll help. But anything much over 10mph is going to trash the bumper and push it back into the body/frame anyway. The bumpers are still bolted to the frame in the same manner as the earlier bumpers, just a couple of bolts and captured nuts inside the frame. Heck, even the shock mounted bumpers aren't really an improvement in a higher speed impact. Yes, they absorb some energy, but once you hit them hard enough to bottom the shocks out the rest is going into the frame.
Truly, the frame is the weak link. Even the non-reinforced bumpers and brackets are tougher than the frame they're bolted to. As far as the bumper jack is concerned, those things are sketchy anyway. Better off without them.
