kpagenk
KrisP
Can I assume that if the cabin heater switch is OFF (vacuum activated heater control valve), the leak will stop when the heater core is empty? (I live in FL so no heat is not a problem). Thanks.
Thanks!Just loop the heater hoses at the engine, the heater control valve only shuts off one side of the heater core
