[Found!] 73 Dart Left Window Downstop
Sorry, I don't have a pic as the piece is missing. It's the big rubber chunk that sits in the bottom of the door. It has a small tab on the bottom that fits into a slot in the door. The FSM just shows a block in the exploded drawing (no pic). DMT used to have a pic as a part in development but that is gone now. Nobody seems to have one to pull that I could pull a picture of.
Thanks
I look around. I may have 1
DM me if this is what you need !
Thanks Al. That is similar but looks like it may be a different model. The bottom of mine is flat except for the mounting tab and its roughly as tall as it is thick.
May be wrong but from your description it sounds like a downstop from a 74-76 Dart Sport or Duster.
Let me check the barn, I have a 74 Dart Sport, and I thought I ordered replacements so I might have the extras somewhere. Give me a moment.
Sorry, mine are the same as Rat Rod Al, and I guess I did not order replacements as these look fine and I can't find any new ones in the shop. Good luck.
Thanks for checking. I've done a lot of looking and these don't seem to be available anywhere so it's probably going to have to come off a car with a wrecked driver's door.
Thank you Big. I'd been checking ebay and didn't see those. However, my understanding is that 73 and up are different than the 70-72 even though the ebay listing shows 70-76. I don't know if the difference is cosmetic or more than that.
Ones on ebay are the same as builder guy posted and his car is 73 or later.. should be good
