Avispa
I have a 73 Dart Sport for sale, Want to drive something different? try this! Way to many parts and mods to list, can email complete details if interested. $5500, car is located about 30 miles SE of Atlanta Ga, 1/4 mile off of I-20 East
Dana 60
400 BB
Passon 4 speed
single turbo
mini tubbed
20 gal fuel cell
MSD
Stock Spec fully rebuilt 400 B motor.
Edelbrock Performer cam degreed in at 112 degrees.
Mopar Performance 1.6 ratio roller rocker arms.
Totally rebuilt heads with new seals, valves, springs, and retainers.
Mopar Performance M1 aluminum intake.
Holley 750 double pumper with proform main body, modified for blow through operation.
Modified headman 1 3/4 " tube headers.
Arp stainless header studs.
CSI electric water pump.
All AN and braided lines for cooling system, reverse flow cooling setup
Northern 28 1/2" X 19" aluminum double bypass radiator.
Dual 12" electric fans.
Hanger 18 Turbo air to air intercooler, 30" X 18" x 4" mounted behind front bumper.
K&N 4" tube and air intake filter
Turbonetics 60-1 TO4 turbo, P trim .96 A/R turbine and .72 A/R compressor.
Dual 38MM Tial wastegates with 9 PSI springs.
Single Tial red anodized 50MM blowoff valve.
Extreme Velocity turbo carb hat.
Braided stainless turbo oil feed and return lines.
Engine block modified for turbo oil return -10AN line.
All stainless T band clamps on turbo tubing connections.
McLeod SFI approved flywheel with adjustable weight for use with internal or external balanced motors.
Fully rebuilt Mopar 833 4 speed transmission with Passion modified street slick shift syncros and 3:09 low gear.
Custom 3 1/2 " driveshaft with 7260-1310 front u joint and 1310-1350 u joint in the rear.
Moser engenieering Dana 60 rear axle.
Girdle cover for the Dana rear.
Moser spool.
4:56 Richmond gears.
Moser 35 spline rear axles with press in Moroso long studs, also drilled for 5/8" studs.
Carrera adjustable rear chrome shocks.
Frame connectors welded in.
Rear has been mini tubbed and the rear springs moved in for tire size and clearance.
Rear SS springs.
Front inner fenders removed and tube bracing installed from firewall to front chassis.
Ansen shattershield safety bellhousing.
Brand new less than 30 miles, Centerforce Dual friction clutch, pressure plate and throwout bearing.
Mr. Gasket/Hurst vertigate shifter with seperate reverse lockout.
RMS tubular upper control arms.
Tubular heim joint strut rods.
All new control arm bushings.
Fatman Fab 2" dropped spindles.
Custom built K frame, allows the oil pan to be removed with no interference from steering etc.
This oil pan drops straight down.
10" front disc brakes.
Stainless steel brake lines on front.
10" X 2 1/2 rear brakes.
Fiberglass front bumper.
20 gallon aluminum fuel cell with anti slosh foam lining mounted in trunk.
1. GM fuel level sender and rollover vent,
2.-12AN braided steel line from fuel cell feed to pump.
3. Russell -10AN Push Loc supply and return lines from fuel
cell to front.
4.-10AN braided steel supply and return lines from regulator
to Push Loc lines.
Aeromotive A1000 fuel pump.
Aeromotive 12304 10 micron inline fuel filter.
Aeromotive 16302 solid state fuel pump controller.
Aeromotive 13204 boost referanced bypass style regulator.
New 800 CCA battery mounted in the trunk.
GM 1 wire altenator.
Painless 6 gang illuminated and fused rocker switch panel,
switch 1, engine start
switch 2, ignition on and off
switch 3, fuel pump on and off.
switch 4, water pump and radiator fan on and off
switch 5, accessory 1 switch.
switch 6, accessory 2 switch.
Battery shutoff switch mount on lower pass rear bumper.
Denso mini starter.
MSD SS Blaster coil
MSD 7AL-2 ignition
MSD 8981 ignition timing computer.
MSD 8762 Boost Timing Master with controller
MSD 8739 two step module.
MSD 8950 rpm activated switch.
Hurst Line Loc.
Simulated carbon fiber instrument panel.
Autometer Sport Comp Speedometer.
Autometer Sport Comp tach.
Autometer Sport Comp oil pressure guage.
Autometer Sport Comp water temperature guage.
Autometer Sport Comp Boost/Vac guage.
new custom red and black reclining bucket seats.
new black dash cover.
New red carpet.
Aluminum rear trunk panel divider.
Snap on and off custom steering wheel.
Custom 15" X 10" steel wheels with 6.5" back spacing.
M&H Et drag tires on rear.
New 165-R15 Dunlops tires on the front.
15 X 3.5" Weld Rodlite rims with centers on the front.
Probably less the 100 miles on the car since built !!!
Here's a vid of the car before I installed the 4" muffler
http://www.youtube.com/tinmanozzie
Dana 60
400 BB
Passon 4 speed
single turbo
mini tubbed
20 gal fuel cell
MSD
Moser spool.
Rear SS springs.
cell to front.
to Push Loc lines.
Denso mini starter.
MSD SS Blaster coil
MSD 7AL-2 ignition
Hurst Line Loc.
New red carpet.
