Finally parting with my project I haven't been able to work on for three years. Started as a slant six car, green with white vinyl top. Converted to 360 with schumacher mounts. TCI streetfighter 727 trans with stock converter, 8.25 rear with posi unit installed. 2 1/2 inch dual exhaust with hooker aero chamber mufflers. Feel free to ask questions, not parting out or really pressed to sell, no super low ball offers, please. Have clear Maryland title. Email for pictures. Getting file too large errors.
Engine: stock bottom 1985 360 with .443/.465 cam, edelbrock 600 carb, orange box module. Engine freshened with new oil pump and double roller timing chain and gaskets.
Trans: TCI Streetfighter (Jegs)#890-111100. Numbers on side of case if you want to look.
Rear: Early 8.25 rear for Abody with eaton trac-loc clutch type posi and 3.55 gears. leaking at pinion seal currently, will need checking.
Suspension: .920 torsion bars in front, replaced weak 4 leaf with 5 leaf rear springs. front suspension bushings replaced with just suspension rubber bushing kit. Steering box, center link and idler setup from 71 dart due to oil pan clearance issues after eng swap.
Tires: rear: M/T dot 235/60r15 on 15x7 stock rims, front: kelly 165r15 on 15x5.5 stock rims. all rims painted.
Needs: Needs body finishing, needs quarter panels installed (included with filler panels to trunk), needs to have pinion seal fixed, needs aluminum radiator, just have one I had sitting around in it to move it around, wiper trans seal leaking,
feel free to ask any questions. Asking $3500.00 obo.
