[SOLD] 73 Duster 360 mag FS/FT
player1up
orlando FL
Rating - 0%
0   0   0
Well it's time for me to move on to some other projects so the Duster has to go.
73 Gold Duster
Orlando FL
$6,000 or trade for wrangler. EFI, A/C, 6cyl
Drivetrain:
99 Dakota R/T 360 with stock EFI and serpentine setup. ( was told it had about 60k on it )
Aluminum lower plenum plate installed.
98 Ram 1500 46RE trans.
98 Ford explorer 8.8 3.73 geared open diff with disc brakes ( I have a posi center that will go with the car but it needs a rebuild )
80's smogger manifolds with 2.5 inch dual exhaust. ( car has power steering currently...the reason for the smogger manifolds )
Adjustable proportioning valve.
17" mustang bullet wheels. 235/45/17 front 245/45/17 rear
Floor shifter from jeep cherokee in center console.
Suspension:
LCA bushings replaced about 3 months ago.
Stock v8 torsion bars
Front sway bar
Durango rear spring mod
Interior:
Fold down rear seat option added. ( bottom is ripped )
Manual adjustable buckets from 2000 Dodge avenger.
A/C is working and cold ( r134 )
modified door panels with pockets.
Retractable shoulder belts from +75 Duster
Electric trunk release
Other:
New Steering box
New gas tank
Aluminum radiator
Shaved drip rails and marker lights
Chrome bumpers ( also have another set of steel bumpers "painters" dinged a bit )
Aluminum spare.
Subframe connectors
Here's what it needs:
Some interior work: Door panels and rear seat.
Floor pans have a couple of small holes, they were patched about 8 yrs ago but should have had full replacements.
Paint: It's had the body work done and was shot with matte metallic grey.
Trans leaks at the speedo drive but otherwise super solid drivetrain.
PM me for contact info, pics or any questions.
Thanks
Matt
