Howard1784
1973 PLYMOUTH DUSTER$8,500The motor is a rebuilt 360 with about 3,600 mi. The 904 transmission was also rebuilt front to back with a reverse manual valve body and new Pro Stick shifter. The rear end is Ford 9 with a new posi and 3.73 gears. The front suspension was completely rebuilt with a Just Suspension kit. The entire undercarriage is solid, frame, floors etc. The car is very solid! There is some bubbling on the right rear quarter panel. $1,000 was just invested on a custom fan shroud, dual electric fans pushing 4,500 cfms of air, separate relays for ea. fan, Be Cool aluminum radiator and a new Powermaster alternator. Runs 180-190 degrees. I am very pleased with the cooling system Holley 750 dbl pumper New oil pan w/ windage trayNew front brake calipers and front brake lines, theonly line that has not been replaced is the one fromthe front to the rear axle.Mopar valve coversNew Dynomax mufflersExhaust cut outs. MSD 6A ignitionNew wiresNew Battery in trunkB&M line lockB&M Flex plateNOS Powershot 125 HP (never used)Suspension:Front power disc brakesPower steeringFront end alignmentNew front shocksCustom welded frame connectorsNew tires all aroundBody & Interior(New r/r ¼ panel to go with car), new door weatherstripping, cat whiskers, package tray, Headliner ,exterior door handles, gas tank w/ sending unit,
Car is in Northern, Virginia . Feel free to call me 571.238.7914 $8,500
