I'm looking for photos and help mounting location for a electric fuel pump,aeromotive pump and filters, car is hard lined for fuel from the bottom of the firewall in the engine compartment, along the inside of the right frame rail to the rear tire hump in the rail, then each end has a aluminum block that is split and pinches together and is plumed at each end of the fuel line and return line. Where the hard lines end and are plumed at each end to the carb and the return line will be braided lines.The fuel cell is sitting in the spare tire well and plumed out the bottom. I really want to do a sweet job and a safe job. Car is mini tubed and rear end narrowed , please help... send photos.:banghead:
