[Found!] 73 Duster LH Lower A-Pillar Where the hinges bolts to
Are you referring to the actual structural A post that needs to be replaced? Like this?
AMD makes them if you dont want to mess with cleaning up original stuff.
If that is a Apillar yes but mine is rotted all the way up because the car had a vinyl roof and rotted the whole front and on the drivers side and all the way down the LH a-pillar ,I have a roof coming but can't find the part I need I do have the part you showed coming.
I have a complete cowl from a 1970 Dart. I could remove that pillar and ship........But you say you have the part coming already??
I should have the part, but i need to check condition.
I will try to post a picture tomorrow.
Thanks!
burg
