flathead31coupe
After doing some looking. I need to see if the mounting of the duster steering column. Would be as follows...two studs in front...three plastic inserts Rosette. washers. Driver side stud gets A Rosette washer then a washer nut...passenger side stud gets A rosette washer, Sairated nut then ground wire then another Sairated nut. Last one gets a Rosette washer and a bolt...
