[WANTED] 73+ front sway bar
Elmer-FN-Fudd
Florida
Looking for the sway bar and associated parts that are needed to put on my car. this is for a 71 duster with 73+ K member. It already has the correct factory 73+ lower control arms with tabs for the sway bar.
I've got an Addco but it's for a car without factory swaybar tabs. Don't know if it'll work with the factory set up. It is fat and goes through the 73 K frame.
I would need all the parts to install, my lower control arms have the factory tabs already, so yes I would need the brackets and end links.
that would be great @junkyardhero, would definitely be easier to get all the pieces together. I would assume that I would need to get new bushings but that won't be a problem.
@66Valiant528 is the Addco bar the one that attaches to the lower shock mount?
I believe the 90° bracket for the end link can be mounted to the shock bolt. I have the complete set up but dont know if it will work with your factory tabs. Also have an Addco rear sway bar set up from our 73.
Not for a 73-76, the bracket is in the center of the arm, not on end by shock bolt.
It was on my some 73 Duster and I just don't recall as that car has been gone for 5 years now. But it was an Addco kit for that application and we had no control arm tabs. May be longer than a factory bar. Don't know. I can measure it if anyone needs me to.
