[SOLD] 73 Spool Motor Mounts small block
68GTconvert
Mill Valley, Ca
73 Spool Motor Mounts small block - These are in very good condition the rubber isn't cracked.
$50 plus shipping
What are these out of ?
Will they work on all small blocks...ie 340/360 ?
Hello, I was wondering the same thing.(hey John!). Would they work on a 318 and not a 360 like the Schumacher ones? I didn't know there was a difference. I'm looking for a v-8 spool k-member if you guys know of one locally. Thanks! Sorry for the semi-hijack!:D
if 360 mts put me in line. distance between block ears (inside to inside) is 2&3/8 on the 318 and 1&15/16 on a 360 (Dr side)/pass is the same.
On side says 2326 and the other 2325. Oreily's Auto Parts says these are 360 mounts. Here are some pics.
I called O'reillys and asked for mts for a 74 dart with a 360 & they came up with your numbers of 2355 and 2326 & with an out the door price of $22.50 for both tax included I could not resist. I got em & they 318 mts ( the DR side is different). I mocked em up & with the DR 360 rearmost block ear being closer to the front ear they will work on a 360 with some spacers between the rear ear of the mt and the rear ear on the block but I (re) called O'reillys & had em double check & it came back the same, that the 2355/2356 are for a 360. That is the latest. EDIT meant to say 2325 and 2326
Yes I have 2325 and 2326 on the O'reillys receipt in front of me. definitely a 318 DR mt & they swear they are listed for a 360. The spacers will work but there is an issue somewhere
