[SOLD] 73 up BBP Disc brake set up.
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
For sale is a pair of Large Bolt Pattern Upper Control Arms. They have been media blasted and painted semi gloss black. Also include New upper control arm bushings and New ball joints. The spindles have been media blasted and painted semi gloss black. Includes New wheel bearings both inner and outer and new grease seals. Comes with a pair of good dust shields, caliper mounting hardware, media blasted. Also UCA mounting cam bolts and nuts also media blasted. Includes lower ball joint mounting bolts an nuts. Included are the two caliper stands both media blasted and painted semi gloss black. Spindle nuts , washers , retainer rings. All you need is calipers and rotors. Other wise a complete change over from drum or SBP disc to BBP disc brakes. $450.00 plus shipping
Are the calipers and rotors readily available?
Yes, I have gotten both from Advance and Dr.Diff in the past. Dr diff has calipers and pads for 115$ and drilled and slotted rotors for 145$. Not sure on advance prices, but they usually have them at warehouse.
Sold . P M SENT
You can pick both up at Rock Auto. They are very reasonable and I could have included them in the sale. But the shipping would have been a killer.
