..well i have a book that says .060 down for 1974 318 but was hoping someone had an actual measurement.
..at .060 i would think about 8:1 comp...comments?
The compression is greatly affected by the piston dome height and the size of the combustion chamber in the head.
I have run through the compression calculations for the numbers listed in the service manual and they don't match up. There is some "fudging" somewhere. I use the stock configuration as the baseline and then adjust for the parts that are changed/different.
