the green and yellow on the start side for sure go to the ignition box. Can’t quite tell where the green and red wire go? Trying to eliminate ballast resistor and stock ignition box and add an msd ignition box. Found the start and run wires I need to hook together to power box just unsure about eliminating the green red wire.
