74' Duster 904 LINKAGE help
Sebambam
Dallas , TX
Hy guys
I need help with assembling the linkage on my 904 column shifter car.
I was not able to find good pics to lead me.
Dies anybody have pics on how this brackets and linkages assemble on here?
I assume the slotted rod is on the carb for the kick down?
Where do the brackets locate? Especially the bracket with the lever?
Well I think I got it figured out.
The brackets are oem intake brackets fir the linkage to the Throttle.
I need a z bar located bracket on the trans
And a kickdown rod or aftermarket setup since I have a aftermarket intake
Got it....
Since I have a aftermarket intake I just get a kickdown cable setup.
Otherwise I just need tge z bar pivot bracket on the trans.
I think I fab my own, instead of spending 30+$ on a a simple L bracket
