74 duster slant 6 to 318 conversion
dustymidget
New Member
ohio
I recently bought a 318 with a 904 trans already attached. I already acquired a motor mount conversion kit, but what else will I need to get the engine in and the car going?
Kinda vague, but I'll try:
Assuming the slant was an automatic (904), all the shift linkages and driveshaft should bolt right on. You should even be able to tweak the trans cooler lines to fit.
Assuming the motor came out of a passenger car and not a truck/van, the oil pan should be okay.
Assuming the motor came out of an A body, so you'll have the correct kickdown linkage to clear the A body firewall.
Assuming the engine came with accessories (pulleys, p.s. pump and brackets, alternator and/or brackets, and whatever AC brackets/compressor you may or may not need), you should be okay there, too.
Some of the wiring harness connection points may be too long or too short for the new engine, so be prepared to do a little work there.
Assuming the 318 is a later one with electronic ignition, that should all plug and play.
Assuming that your 318 isn't one with the Lean Burn ignition, otherwise you'll have to swap that out- distributor, carb, and a few other miscellaneous details.
If the 318 came with exhaust manifolds, make sure that they're A body manifolds.
Mainly, you will need an appropriate A body V8 radiator and shroud, and POSSIBLY a shorter V8 throttle cable.
An exhaust system.
Possibly some other details I'm forgetting, but that's the gist of it.
It would be handy to know the year/original application of the 318...
An exhaust system.
Thanks for the response, there is a lot I didn't even consider from the start. My father nor I are very exceptionally handy when it comes to car stuff, but I am still going to try lol
My slant and the new 318 are both equipped with a 904, and I think the 318 I bought was originally from a 71/72 road runner.
My career change is finally settling down, so starting soon, I think I'm going to get back into this project. there is obviously some stuff I am going to need to order. Is a lot of it easier to do after the engine is installed? I am assuming the radiator would be easier with the engine out, but I really don't know.
