74fldart
im working on the engine wiring for my 74 and it looks like im missing a section. i have the 3 bulkhead connectors attached and the main harness routed around and to the headlights , it was all unhooked and stuffed in a bucket when i bought the car. i have the starter solenoid mounted along with the electronic ign. module and the ballast resistor. my problem lies with the wiring that routes across the firewall toward the blower motor. this is where a connector is located , but im missing the rest of the wiring that goes to the alternator and regulator, the ign. coil and i guess the ac compressor wire and the blower are on there too. anybody with a 74 know what i mean? or am i way off base with this? i guess i could try to make my own harness. any one know for sure what hooks up to this connector which is over by the ac and heat pipes at the firewall? it has i believe 6 lugs in it.
