swissvaliant
New Member
Hello everyone. i own a 74' plymouth valiant which was produced in switzerland (schinzach).
Today I replaced the speedometer cable. after a short test drive, smoke suddenly came out of the middle of the dashboard. I then unplugged the battery and looked under the dash for a moment and didn't see anything obvious. however, neither the light nor the ignition or anything else works.
checked the cables and noticed that two cables on the negative pole of the voltage display are burned through. I have renewed the connections and checked the fuses. unfortunately I still have no electricity.
Do you have a tip what else I could check?
thank you for your help!
greetings
Pascal
greetings
Pascal
