74 valiant to 71 duster
deliriumx
Member
ok so i was wondering if the rear end and k member from a 74 valaint would fit on a 71 duster. the duster is a slant six and the valiant is a v8. also would anything else fit? like the front end?
The k member and the rear will definitely fit.
In fact, it should be bbp front and rear and that's a great upgrade to your Duster.
You are planning to go with the small block instead of the slant six right?
It will all swap over. If you take the discs be sure to also swap the upper A arms and the proportioning valve.
