[Found!] 742 7260 10 spline yoke
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I picked up a 68 742 center section but it needs a yoke.
Let me know what you have.
U joint bolt holes, u joint bearing mating surfaces and seal surfaces must be in excellent condition.
I forgot to add Nut and Washer is a plus.
I had one last summer....let me check.
Its off my old 741 and is getting degreased. You should have seen it before the pics. I'm not sure about the mating surfaces yet. The other one for sale is closer to you though.
A 10 spline 7260 is a 10 spline 7260.. it matters not whether it came from a 741 or 742.. Hell even the early 489s used 10 splines. Happy hunting
I have the nut and washer,seal surface is good. I bead blasted if you couldn't tell.
