jdragster
New Member
I have a 742 case 8.75" rear end. I wanted to put in new bearings and gears. When I took out the old pinion, the front bearing only needed a tap to be removed from the pinion. It was a Richmond Gear 4.57 gear set. The new Richmond 4.57 pinion has a .0015" press fit for the front bearing. Should the front bearing fit be this tight or should it be a snug fit that needs to be tapped onto the pinion shaft?
