HemiSSDart
Dartus Interuptus
1975 440 short block with new rings and bearings standard bore original pistons with new cross hatching in cylinders. Took a running engine with no ridge and freshened it up. I did not clean the block just a quick refresh. Has 971 oil pan. Was going to use the closed chamber 1963 413 heads 2463200 casting number to have decent compression and they are fresh. Will include factory cast intake of your choice, have almost every year intake. Also valve covers, water pump housing, distributor, and other parts if needed, all for $900 obo, shipping on your dime or I may be able to deliver as I transport cars around the country.
