'75-76 Parking Brake pedal?
goldduster318
Overzealous Car Modifier
Lake Orion, MI
Does anyone have any pictures of the '75-'76 parking brake pedal installed in the car? I'm considering doing some modifications which would make me unable to use the normal 1970 "Knee Knocker" hand brake. This could be an easy way to make the room I need under there.
Thanks for any help!
I have the same issue. from what i understand or have been told the kick panel on the 76 duster was different with provisions in the metal for the foot operated brake.
I am looking at using a handbrake from a Holden HQ and mounting it on the floor between the seat and the door ( it drops back down again so you don't impale yourself getting out of the car) just trying to work out how to get the cable to work
I have a complete parking brake assembly from an early B Body, which I am fairly certain is the same one used on 76 A Bodies.
Looking to get $50. PM me if you think that can work for you.
I'm pretty sure I have the ebrake setup from a 76 Duster including the kick panel. Might have scrapped it not thinking anyone would want it. I'll check
Riddler
