75dartron
Active Member
Can someone tell me if a BFG 245/60/15 will fit on the rear of a 75 dart swinger with stock rally rims? I believe there 15x6" The vehicle is stock.
Nope.
First, a 245/50/15 needs at least a 15x7" rim.
Second, you'll need to max out your backspacing if you want to fit a 245 on a Dart without rolling the quarter lip.
A 15x8 with ~4.75" of backspacing might work. But a 245 is right about where things start getting entertaining with the stock spring location.
.....he said a "60" series tire...and yes it should fit...245/60 tire on that rim will work fine :glasses7:
I am running BFG radial T/A's 245/60/15 on the back of my 73 Dart Sport with steel wheels and a 8.75 rearend out of a C body 67 Coronet uncut. Here is a pic of the car and a pic of them under my Duster as I needed to run them on my Duster to check a vibration.
Not to Poo Poo on anyone, but I have 245/60 R15's on the back of my '75.
4.75" BS and there is no more room inside or out.
That being said, they fit and I have never had a rub outta them.
Check the photo, you can see they fit well up inside the ...well.
As said above, the crucial issue is the BS. Tried a set of same on a 4.5" BS and it was a no-go, rubbed on the lip.
With the 4.75" BS, there is 1/4" inside and out with my BGF's.
They fill it well I think.
You decide.
