75 Dodge dart sport
mower parts - harnesses are dried out and cut in places, thanks for the inquiry - did you try mopar brad?
this car has good:
Door shells - interior door panels dried out and broken, may? be fixable - interior is beige / wood grain
Front fenders good
Hood good
Trunk lid good
Bumpers with hydraulic pistons and extensions appear very solid
Rear seat untorn - surprising for a southwest car
Front seat bench not horrible
complete set of black seat belts - bench front and rear - six sets
car has power disc brakes
318 V-8 assume 904 automatic
radiator has be recored
radiator shroud and coolant overflow bottle appear unbroken
complete set of four hubcaps - minor dings on one or two very good overall
Mirrors (exterior), front fender top indicators, front grille and related trim, and rear fascia piece with tail lights were being taken as I was taking these pics. This is not my car, it is in a u pull it in East El Paso.
dammit......its only 400 miles.....or 800 round trip:wack:
I would go grab the entire AC setup condensor, compressor, lines, control head, AC Heater Box......the Cluster, HVAC trim, glove box door...door panels F/R....sail panels, upper door panel trims, arm rests, steering wheel....front suspension assemblies...brake booster....I'd be there about 3 hours.
Too bad I dont need all that stuff terribly.
Pics of the interior dash. And two more underhood pics.
There is not much of a local market for this type of metal (73-76) big bumper parts. Would suspect the brake system will be the first big item to go.
Prine i sent you a pm.
was able to sell the knuckles/steering arms, rotors and calipers locally to a mopar restorer. I did also get the upper a arms, lower control arms, and strut rods. upper a arms (big ball joint) $95 shipped lower 48 states - all hardware is good and usable - does need new rubber upper bushings but cam bolts and washers are good and un stripped.
lower control arms with torsion rod tensioners - low rust $125 shipped 48 states
strut rods - pair with hardware - very good $45 pair shipped 48 states.
if any one wants the torsion rods themselves - am going back next week to get the K member let me know.
this is an update on the dart sport strip - if you can call it progress
got the front suspension and control arms and struts yesterday
sold knuckles, steering arms, rotors and calipers to a local mopar restorer
radiator, shroud and overflow bottle are sold - were gone yesterday
winston - someone took the steering wheel center (triangular type)
I am after the a pillar inside trim both sides and the inside roof rail trim both sides if in good condition. I am also interseted in the entire heater demister controls plus the facia plus postage to Australia.
Would have liked to have the stereo but looks like someone swiped the knobs.
sale pending on upper control arms
am going back to yard either wed. or thurs. pm me by then if interested in anything remaining
parts that are gone:
front suspension and brakes - booster and master may? still be on car
i still have LCA's available.
radiator, overflow bottle and shroud.
a/c condensor and lines to firewall were gone - the compressor was still bolted in place - and all dash parts and controller were there.
hubcaps, exterior mirrors and wheel opening mouldings were gone.
five good 14" BBP rims were still on or with car
lots of good parts left
this car may? have a 727 trans - any experts?
master cyl
booster
starter
exhaust manifolds
steering box
8 1/4 rear end
fenders
hood
trunk lid
doors
seats
seat belts (black)
the rear trims and bezels were taken soon after i took the first set of pictures. did mention that in an earlier message in this thread. editing system does not seem to allow one to delete pictures. have some interior parts from this car newly posted in the interior parts section.
probably one month or so to crush.
any one interested in:
big bumpers with bumperettes, very good condition, pistons and attaching hardware excellent
front fenders - assume they fit 73-76 regular dart and this model only
pair of doors
flat hood
trunk lid - no lower rear seam bubbling
front and rear bench seats
more
I need the long brake booster support bracket that goes to the lower firewall asap. $?
i have a rear seat out of a 74 swinger two door hardtop. Bus shipping out of here (las Cruces to Colorado) should be around $50 - $65.
i don't know if this parts car has a brake booster support rod. please clarify where this part is. the under hood brace rods had been taken shortly after the car entered the yard - probably by the same visitor that took misc. small trinkets and the rear fascia piece.
the trunk lid is clean. Am guessing Bus shipment to NY - close to $100
fedex and or ups - more.
