76Scamp
Well, I did the drive up last week and they said they could take care of me. I went back on this past Thursday to pick it up and I must say that it is the nicest looking thing on the car. $155.15 after everything was said and done. I got it working today, but two other problems have come up; only one with the a/c though. The clutch coil has burned out. I was driving with nice, cold air and it started getting warm, pulled over and it wasn't running. I check pressure and it had enough to run. I checked and I'm getting power up to the clutch, but there's no continuity through the coil. Now the question would be, would the coil from a 65 Fury with a two groove pulley fit my 76 with a single groove pulley? I don't want to buy the whole assembly new because that alone is more than what I have into the system, and if I can make this work, I will. The other issue, which is unrelated, is last week when I drove the car up it ran perfect the whole way holding 80MPH on the 120 mile round trip. This week, it started overheating about halfway there running at the same speed and it wasn't any hotter out. Engine had a new head gasket back in 13 and I was told the cooling system was flushed. I still have the original radiator and it has a six blade direct drive fan. I took the 195 thermostat out and put in a 160 just so I can get around for a couple days until I have a chance to check out everything. But that brings up a different question: is 195 right for a slant six? To me it seems to hot for a carburetor, but would be good for a newer, fuel injected engine.
