[FOR SALE] 8 1/4 COMPLETE REAR W/SPOOL & 4:88'S - SLICKS - 4:56 GEAR SET - 5.2 MAGNUM MOPAR PERF ECU
DAKOTA SPORT
Member
Boston
Rating - 0%
0   0   0
8 1/4" COMPLETE REAR W/4:88's or 4:56 RING & PINION WITH INSTALLATION KIT
ALL GOOD COMPONENTS (LIKE MOSER AXLES & SPOOL) 88'S JUST INSTALLED NO MILES OR PASSES MEASUREMENTS: BACKING PLATE to BACKING PLATE-54 3/4" - INSIDE PERCH to INSIDE PERCH 41" - OUTSIDE PERCH to OUTSIDE PERCH 46" - CENTER PIN to CENTER PIN 43" ---- IN THE TRUCK (DAKOTA)WHEN SHIPPED FROM WEST COAST - has 4:88 GEAR IN RIGHT NOW ALSO HAVE A TAKE OUT SET OF 4:56'S WITH INST KIT W/BOTH SET'S OF GEARS $1800 WILL SPLIT THE 4:56'S AND SELL ALONE
(4) (TAKE OFF)M/T RADIAL STOCKER SLICK'S --- both set 30x9x15
(2) (TAKE OFF) GOODYEAR RADIAL STOCKER SLICK'S (ONLY GOOD FOR CHASSIS SET UP}
(2) M/T 29.5x9.0x15 (3056) WITH TUBES ONE SEASON OLD AND NOT USED WEEKLY - IN GREAT SHAPE AS WELL $300
(1) NEW MOROSO 89552 0-15 LB 4" TIRE PRESSURE GAUGE NIB - $120 OBO
(1) Mopar Performance High Performance Computer P5249516 MODIFIED AT MOPAR HAS RAN 12.41@101
ThIS single board engine controllers are direct replacements for the production computers and provide increases in both horsepower and torque from 1,600 to 5,200 rpm. These Mopar Performance exclusive computers also provide easy-to-install power improvements without affecting drivability. They require the use of premium unleaded fuel FEEL FREE TO CALL FOR ADDITIONAL INFO$200 508-TWO SIX NINE -9611 OR E-MAIL ba1927@aol.com
LOT'S OF MISCELANEOUS PART'S MSD - ACD - BORLA COLLECTOR MUFFLERS
I have had the rear since 2000 and the spool and axles came from a vendor on the west coast I will look today while I am in the garage as the name escapes me right now - just put the 88s in and everything still looks great
