mopar56
so my son just acquired a 8 1/4 rear to put in his 74 Duster from a member here, we are going to do a disc brake conversion on it using 1995 Grand Cherokee rear disc parts using the info from this site from an earlier post, my question is could we also use the limited slip carrier and pinion from the same donor Jeep?, we know the caliper brackets and rotors will bolt right on but if the carrier would fit we could convert the 2:71 ratio open to a limited slip, just not sure if the sure grip used in the Dodge 8 1/4 is the same as the carrier in the Jeep is it sure grip or Trac Loc?, anyone done this before?, the rear we are using was from a 77 Aspen
