8.25 brake upgrades
mopardrt
Detroit
Is there any "CHEAP" brake upgrades to make to my 8.25 rearend in my 1974 dart swinger?
It has 10x2.5" BBP brakes on it now right?
Cheapest would just be to upgrade to semi-metallic or carbon semi metallic pads (Firm Feel). WAY better than any of the organic pads, if that's what it has now. They also make finned 10x2.5" drums, they're a bit heavier duty than the smooth ones. More material, better cooling.
Next would probably be to grab a set of 11x2.5" backing plates and hardware. They came on B/C body cars and some of the trucks that had a 5x4.5" pattern, and ran late enough to turn up in the wrecking yards. They're also pretty common on ePay. A finned set of 11x2.5" drums and semi-metallic pads is a pretty significant upgrade, that's what I run on my Challenger now and its a noticeable difference. But, you add a decent amount of rotating mass with those big old heavy drums.
After that you're looking at disk brake kits, which definitely aren't "cheap".
Here's a list of donor cars for the 11x2.5" brakes. Keep in mind they were an option on some of them, so even if you find one of these models in the yard it doesn't guarantee it'll have 11x2.5" drums. And, some of the trucks have a larger bolt pattern, although you could have those drilled if you really wanted to.
CHRYSLER 300 (1966 - 1971)
CHRYSLER CORDOBA (1975 - 1982)
CHRYSLER FIFTH AVENUE (1983 - 1989)
CHRYSLER IMPERIAL 1974
CHRYSLER LEBARON 1981
CHRYSLER NEW YORKER (1966 - 1982)
CHRYSLER NEWPORT (1966 - 1981)
CHRYSLER TOWN & COUNTRY (1966 - 1995)
DODGE ASPEN (1976 - 1980)
DODGE B100 (1971 - 1980)
DODGE B150 (1981 - 1984)
DODGE B200 (1971 - 1980)
DODGE B250 (1981 - 1984)
DODGE CARAVAN (1991 - 1993)
DODGE CHALLENGER (1970 - 1972)
DODGE CHARGER (1970 - 1978 )
DODGE CORONET (1970 - 1976)
DODGE D100 PICKUP (1972 - 1979)
DODGE D150 PICKUP (1977 - 1984)
DODGE DIPLOMAT (1981 - 1989)
DODGE GRAND CARAVAN (1991 - 1995)
DODGE MAGNUM (1978 - 1979)
DODGE MIRADA (1980 - 1983)
DODGE MONACO (1969 - 1978 )
DODGE POLARA (1969 - 1973)
DODGE RAMCHARGER (1974 - 1984)
DODGE ROYAL MONACO (1975 - 1977)
DODGE ST. REGIS (1979 - 1981)
DODGE W100 PICKUP (1974 - 1977)
DODGE W150 PICKUP (1977 - 1983)
FARGO B100 VAN 1972
FARGO B200 VAN (1971 - 1972)
FARGO D100 PICKUP 1972
FARGO D110 PICKUP 1972
PLYMOUTH BARRACUDA (1970 - 1974)
PLYMOUTH BARRACUDA GRAN COUPE (1970 - 1971)
PLYMOUTH BELVEDERE 1970
PLYMOUTH BELVEDERE SATELLITE (1970 - 1971)
PLYMOUTH CARAVELLE (1978 - 1988 )
PLYMOUTH CARAVELLE SALON (1980 - 1988 )
PLYMOUTH CARAVELLE SE 1985
PLYMOUTH CUDA (1970 - 1974)
PLYMOUTH FURY (1975 - 1978 )
PLYMOUTH FURY CUSTOM (1971 - 1975)
PLYMOUTH FURY CUSTOM SUBURBAN (1970 - 1975)
PLYMOUTH FURY GRAN COUPE 1972
so any new jeep set up with an 8.25 disc brake set up will work?
