8.25 information
canner78
canner78
weyburn sk
i was wondering if all of the a body 8.25 rear ends had the 27 spline axles. in my web surfing it looks like the 29 spline came out in the 1997 and newer 8.25. is this correct????????
please help!
i hope this helps.
10 bolt rear cover with 8.25" ring gear. Has c/clip axles with 27 spline up until 1997 when it was upgraded to 29 spline.
Ring Gear Diameter: 8.25
Ring Gear Bolts: (10) 3/8 X 24 LH
Cover Bolts: 10
Carrier Breaks: 2.45 / 2.56 & Up
Spline Count: 1.626 / 27
Float: SF
Semi-Float Type:
Pinion Support: False
Axle Lugs:
Compatible with Models:
1/2 Ton Chrysler Van: 1970 - 2004 (Rear)
1/2 Ton Dodge Pickup: 1970 - 2006 (Rear)
3/4 Ton Chrysler Van: 1971 - 2002 (Rear)
3/4 Ton Dodge Pickup: 1970 - 2001 (Rear)
Coronet: 1968 - 1976 (Rear)
Dakota: 1988 - 2005 (Rear)
Dart: 1972 - 1976 (Rear)
Diplomat: 1977 - 1983 (Rear)
Durango: 1998 - 2004 (Rear)
Fifth Avenue: 1972 - 1988 (Rear)
Grand Cherokee: 1992 - 2001 (Rear)
Imperial: 1971 - 1983 (Rear)
Liberty: 2002 - 2006 (Rear)
Magnum: 1978 - 1983 (Rear)
New Yorker: 1968 - 1989 (Rear)
Polara: 1970 - 1974 (Rear)
Ram Charger: 1976 - 1993 (Rear)
Satellite: 1970 - 1974 (Rear)
XJ: 1991 - 2001 (Rear)
XJ Sport: 1991 - 2001 (Rear)
please help!
Yes the 29 spline axles started in 97 with the redesigned Dakota. If you want to use a 29 spline differential in your A-body 8.25 you will need to have custom axles made.
I found a '79 New Yorker with a complete 360 drivetrain.
Will the whole the rear axle assembly drop right in or does it have to be modified?
Thanks!!
Drop into what?
The axle is wider than an A-body axle and the spring perches are in the wrong place. The perches can be cut off and rewelded back on with the proper spacing and if you can find wheels with the correct back spacing you can get tires under the car.
Drop into what?
Oops.. thanks, dgc333! You answered my question despite my lack of information. Its potentially going into a 73 Dart Sport.
I have stock 1970 style 15x7 Rally wheels that I desperately want to keep...so I suppose that I would need to have it shortened.
I haven't bought it yet, still shopping around for an axle.
Are there any relatively common/recent (Non A-Body) vehicles with a direct drop-in axle assembly? The spring perches aren't that big of a deal but modifying the length is something I would like to avoid.
Thanks again for any help at all!
