[SOLD] 8.25 posi center section 4.10 gears
zinser72
Howards Grove, WI
I purchased this center section from a friend and it only has 6 passes down the strip on it. clutch type posi unit. Im only selling it because I ended up going with a 8.75 rear in my duster so this has to go. $250 plus shipping. looks new, can barely see where the pinion rode on the ring gear
its complete with bearings/races and is still shimmed up from the rear that it was it. you just need to check the pattern and go!
