8.25 questions
scamp360
Manitoba
I purchased an 8.25 trac-loc unit with 3:55 gears out of a Dakota now the question is will this unit fit my 8.25 out of a 1975 Duster 360 and where can I get 29 spline axels to fit . Thanks Robert.
Likely going to be cheaper to pick up a 27 spline 8.25 sure-grip and use the axles you have than have axles custom made with 29 splines.
Randy's has the trac-loc units for 8.25's for around $200.
Thanks checked Randy's website and found 8.25 apprx. $343. or maybe another question would be are these rebuildable and can you swap 27 spline end gears for the 29s ?
