[WANTED] 8.25 Rear End
mopar_nocar
Texas
I would like an 8.25 rear end to put into my 64 Valiant. ideally it would be drum to drum and not trash. 3.21+ ratio would be nice, but not mandatory.
Barring that I would take a complete BBP 7.25 IF it had a 3.21 or higher ratio...and wasn't sloppy.
I would take an 8.75, but those are gold plated...
Thanks.
sb
Got a big bolt 7.25 complete drum to drum it's in a 74 duster dont know ratio..$150
Not unless fender tag indicates...its still under 74 duster..
I have an 8.25 big bolt pattern rear end out of a 73 dart The housing has been Powder coating and the rear has been put together but the pinion is not set at the right dept so it needs to be set up correctly it has a brand new Mopar ring and pinion it has a good used suregrip it has the 10 x 2 1/2 backing plates and axles asking 750 and I can arrange shipping through Fastenal if you’re interested
