[SOLD] 8 3/4 323 Power Lok Sure Grip 741
340sFastback
Maryland
For sale is a 323 geared Power Lok sure grip in a 741 housing. The gears, pinion bearings, yoke are original to the housing removed from my car at 70k miles decades ago. Back then I robbed it of its cone sure grip. Shortly after I found an original Power Lok Sure Grip which I put new clutches in after soaking clutches in friction modifier; this was decades ago. The backlash needs to be checked and new pinion seal, included, needs to be installed. Yoke is a 7290 UJoint. Gears/bearings/housing/sure grip in excellent condition. Also comes with a set of pinion pre-load shims which should not be needed because original shims and spacer were retained. Also comes with pinion snubber and bolts. Housing was cleaned and painted cast iron grey back then. Diff has been stored in climate controlled area in a plastic tote protected from the elements until I pulled it out for pictures today. Asking $450 and pickup in Hampstead MD 21074.
