8 3/4 741 or 489 case are they interchangeable ?
trapster
Central Florida
I don't know the difference between the 2 cases but I know I have swapped the 2 out before.
I have a 2.76 single 741 case in the car now
and a not so limited slip 489 case with 3.55's in it sitting on the bench.
I am going to send the 489 to Dr. Diff to rebuild and then put it in the car.
Are they interchangeable and what is the difference ?
thanks for the help.
David
Pinion sizes are different as is the way the pinion bearing preload is set. If you swap them complete they are interchangable. Not all the individual parts are though.
Cool, thanks
I was worried that one of them was shorter than the other.
I don't plan on swapping parts between the cases.
Is the limited slip part the same ?
so they dont come loose over extened peroid of time in forward motion. 1971 was the last year of the left hand wheel studs on the right side of chryslers
