8 3/4 a body axles wanted
I have a pair of OEMs that have been drilled for LBP and have aftermarket studs in them. I don't know what the shipping will be but you can have them for $80/pair + actual SH. Located in CA.
I've got a 1968 B body housing, and axles you can have for that much. Just move the perches in to match the A body leaves (43" instead of the 44" that they currently are).
Mike
I've got a set of sbp stock axles. make me an offer on them, they were going to the scrap yard soon. Shipping would be from 29650 (Greer, SC).
I also have a set if of small bolt pattern ones from a 70 Dart. If you are interested PM me. Greg
Here is a person that had the following for $100
Subject: Re: axles
Date: Fri, 28 Nov 2008 20:09:09 -0600
ok, i have 3 measurements, the spline is 1 inch long, the axle from the spline to wheel mounting surface is 271/4- 3/8 the axle from bearing surface to spline is 25 3/4 see if you can make them work, let me know, others are inquiring,thanks brian
Thanks to everyone that replied for your help. Sorry for not getting back 'til now but busy time of season. If I didn't contact with a pm, I 've already found what I needed. Thanks again.
